LabVIEW chart does not display until present time
I have a program that has several charts being updated on the front panel. All of them are updating properly, but there is a weird behavior in the X axis. The current time is 14:51 UTC. However, three of the graphs display 14:27. The way the plots are done is exactly the same for both temperature and pressure. Is this a known issue? The X axis is set to Autoscale, by the way.
(2,472 Views)
What is the datatype of the chart? Does it include time information? If not, is the setting for x0 different in the properties for the x-axes?
Do the charts have different history lenghts? If so, the leftmost x value will be different once the buffer size has been exceeded.
Can you attach a simple VI that contains the charts in question?
(2,471 Views)
