LabVIEW code to machine code
I have been using NI sbRIO for 3 years now in college for education purposes and it had served me as a great learning tool to build robots, create algorithms and deploy code with minimum development time and intuitive learning for students.
But there always had been a question lurking in my mind that how does a LabVIEW code gets compiled into a equivalent machine (binary) code to work with RT processor? Does it have any compilation tool (like Xilinx HLS tool to convert a LabVIEW diagram into bitstream)?
I know it's a very noob question to ask but I always had an impression from those of microcontrollers (AVR, PIC) where we first write a C/C++ code, compile it and generate a HEX file and then program our controller with a programmer.
Following questions linger on all the time whenever I create a project and deploy it over sbRIO:
1. How does LabVIEW convert a graphical code to a equivalent bitstream for FPGA?
2. Is it a good technique to first convert a LabVIEW VI to VHDL and then perform synthesis, mapping and bitstream? Isn't this process equivalent to some software which converts a VI into C++/C code and then creates a HEX file and then gets "BURNED" into a controller.
3. Does a graphical code get converted directly into machine language on the RT side? I know that for sure that a simple VI, running on a desktop, is converted directly into machine code.
I may not be able to clearly explain my questions but if someone could answer them I'd be really grateful. 🙂
(4,186 Views)
Hi Nap,
LabVIEW uses a compiler to generate executable code - regardless of the target!
There's a compiler to produce code for Windows PCs and there's a compiler to get code for the RT part of your sbRIO. And there's an additional compiler to create a FPGA bitfile (which is based on Xilinx tools).
And no, you don't need to create C code as "in between" step. Search for LLVM as it is used by LabVIEW for some versions now...
There also is an AppNote somewhere here on ni.com explaining that LLVM stuff!
(4,180 Views)
The very short answer is "NI takes care of all of that for you".
NI does compile LabVIEW code directly to machine code for you.  As already said, this same process is done for RT, Windows, Mac, Linux.  FPGA is a little different since NI actually generates VHDL code that the Xilinx compiler can compile to a FPGA bit file.
(4,163 Views)
I wish I were a software engineer to understand the compiler theories.
Thanks for the great stuff 🙂
(4,146 Views)
