LabVIEW communication between SQL server and LabVIEW
The format look like "01-01-00 00:00:00" in the database
Hm, that's not looking really great, first this "date/time" is the Execution Date of the Card test and second I am in internship, the more I can do with LabVIEW better it is so if I can transmit my "Execution Date that I have created in another Sub-VI and transform that string in "date/time" format it would be great, or just use the DB Tools Fromat Date Time String...
I have tried with a value "%d" and transmit it in the same format at TestTime in my DataBase, and it's doing good, that's why I want to transform the String it is the easiest way with LabVIEW commands, LabVIEW can only transform strings into other format? not in the other way?
Message 11 of 13
(1,550 Views)
It works, I just changed the format to string in Excel, then Load it in my SQL code it is looking like "datetime" but I send a string that looks like "00-00-00 00:00:00" so it's all ok now.
About BSTP_Version -> The guy that created the nvarchar make the MAX nchar to 10... So to test with "BSTP_Version" or "BSTPVersion" well it is more than 10 characters, stupid error but well I forgot about that
I am going to close the topic is solved. Really a big thanks to you guys, you helped me a lot, for little things that unlock my big problems about databases.
Anyone have some good documents about "How to send the answer of a request / command and transform it to a string" Then I could start about ComputerName / UserName and other things like that.
It will be ok now I am sure.
Best Regards,
Robin.
Message 12 of 13
(1,546 Views)
Ok it was easy to find, just for the others that have to send it to their databases:
http://digital.ni.com/public.nsf/allkb/03F7257B337CC63E8625754D0082FDE4 Username
http://digital.ni.com/public.nsf/allkb/4B3877DB13370AA586257542003945A9 Computername.
Best Regards,
Robin.
Message 13 of 13
(1,540 Views)
