LabVIEW communication to a 3rd party software
Never. What's the OS? The CONNECTIONS version? You can easily find it running MCB Configuration, or in the MAESTRO About dialog.
Also: if you right click on the UCONN2 control in the Front Panel, are you able to open the Property Browser?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 28
(1,707 Views)
Hi Paolo,
I am using Windows 10 OS. Connections Version 8.01. No i am not able to open the Property Browser from the front panel. I can see the option in the listing when I right click but I can't use it. This is the error that I am getting  when i use an automation open and close reference blocks in the program. Still had the error code 97 without using the blocks.
theMadGreek
Message 12 of 28
(1,680 Views)
What if you try to insert the ActiveX object? Right-click on the control in the FP, then search the UMCBI Connection Control (press U to find it quicker).
Paolo
Message 13 of 28
(1,621 Views)
If the com object is compiled (I think, like .NET, it doesn't need to be), a 32 bit object wouldn't work on a 64 bit LabVIEW. And vice versa.
ActiveX - Wikipedia:
"Despite Microsoft's previous efforts to make ActiveX cross-platform, most ActiveX controls will not work on all platforms,"
Message 14 of 28
(1,595 Views)
HI Paolo,
I tried what you asked. But our windows are a little different and so are the options. I think I am missing some crucial step in setting up here on my end. This is the window I have when I right--click  on the control from  the front panel, and this is not the 'Property Browser' option. I still don't have that option on mine.
theMadgreek
Message 15 of 28
(1,581 Views)
I'm working with LabVIEW 2017, so something must have changed. Can you select UCONN2? What's you LabVIEW version and bit-ness?
Paolo
Message 16 of 28
(1,576 Views)
Hi Paolo,
Yes i can select UCONN2 but i still have the same errors. i even tried connecting directly to the Ortec MCB with the program, but it still shows the errors. I am working with Labview 2021 version 21.0 (64 bit)
Message 17 of 28
(1,565 Views)
@themadgreek  ha scritto:
Hi Paolo,
AFAIK, CONNECTIONS is a 32 bit binary. So, as wiebe pointed out, it will not work. What do you mean with the above statement?
Paolo
Message 18 of 28
(1,548 Views)
Hi Paolo,
What I meant with the above statement is that i had the system connected directedly to the ORTEC MCB rather than going through the switching. Its still the same for that matter.
So you are saying i would need a 32 bit LabVIEW program would work in this case?
theMadGreek
Message 19 of 28
(1,540 Views)
Yes. About the physical connection and other side conditions: you should test them with Maestro in the first place.
If Maestro is able to communicate with the device, also your program can do it.
Paolo
Message 20 of 28
(1,531 Views)
