LabVIEW communication with Gafran controller can some one help me
LabVIEW communication to Gefran controller ca some one help me ?
(3,130 Views)
We need more information.
What controller do you have?
Tim
GHSP
(3,121 Views)
The controller is
650-D-R-R-0-01-G
and
650L-R-R-R-0-0-1-0-1-1-1-1-G
(3,112 Views)
Reading on these they look like they are using:
RS485 serial communication in Modbus RTU
LabVIEW has a Modbus module that you can download.
http://www.ni.com/example/29756/en/
This should get you started. Use the manual. It should have the commands that you can access.
Tim
GHSP
(3,099 Views)
Yes I know that the Modbus RTU is there but I need someone who can setup all the adresses for Setpoint Procesvals alarms ext. ext.
I am not an expert so I need help. 🙂
(3,090 Views)
I think at this point you effectively have two choices:
  1. Become an expert (or at least, learn some LabVIEW (see the top of the forum board for links) and then try things until you have a working program, or at least more specific questions)
  2. Hire an expert: LabVIEW Job Openings subforum
Without a specific question, I doubt you'll find someone here willing to remotely write your entire application for free.
It may be possible to get better help if you read about the Modbus librar(y,ies) available for LabVIEW, the structure of Modbus communication, and make a (potentially quick) attempt at the problem, then come back with a specific error or difficulty.
GCentral
(3,081 Views)
