LabVIEW conversion kit
Hello I need the LabVIEW conversion kit 776874-03. But I do not find download link. Please could somebody share it. Thanks a lot
Message 1 of 8
(10,970 Views)
Hi Lab1994,
you already have the order number - so you simply can order it, it comes free of charge!
Otherwise just call your local NI sales man...
Message 2 of 8
(10,959 Views)
Hi Lab1994
The conversion kit doesn't seem to be available online anymore.
If you contact your local NI support branch they should be able to help you get the conversion kit, most probably in the form of a CD.
For further information.
http://zone.ni.com/devzone/cda/tut/p/id/8387
The link above shows that, as you correctly stated, you need a conversion kit to convert from LabVIEW 3.1.1 to LabVIEW 4.0.1. Anything after LabVIEW 4.0.1 is then compatible with LabVIEW 2009.
I hope this helps.
Kind Regards
Michael
NIUK Application Engineer
Message 3 of 8
(10,950 Views)
Hi Michael,
"Anything after LabVIEW 4.0.1 is then compatible with LabVIEW 2009."
Well, you should say you need atleast LV6 to re-save those LV4-VIs to open them in LV2009... LV2009 doesn't open VIs saved with LV versions before LV6!
Message 4 of 8
(10,943 Views)
Hi GerdW,
You are completely right. I should have mentioned it.
Kind Regards
Michael
Message 5 of 8
(10,932 Views)
How to do conversion from Labview 2011 to Labview 2007? Please help me!!! Smiley Tongue
Message 6 of 8
(9,162 Views)
You should see the link for the Version Conversion board at the top of the page.
Message 7 of 8
(9,135 Views)
There is no LabVIEW 2007.  So when you post a message in that thread to ask to convert, put down the LabVIEW version you have and what you want.  Perhaps you mean LabVIEW 8.6, or 8.5
Message 8 of 8
(9,116 Views)
