LabVIEW could not generate code for the shared variable.You must open the VI in the project that contains the library where the shared variable resides
HI
When I put a network shared variable with fifo RT activated on my diagram, the arrow is broken.and I' ve got this message:
""LabVIEW could not generate code for the shared variable.You must open the VI in the project that contains the library where the shared variable resides""
If I uncheck FIFO RT option for this variable the arrow isn't broken anymore.
I 've no idea how to correct this weird error?
Autodeploy is on, and I've check copy / delete in diagram in tool/options\diagram
regards,
james
(2,989 Views)
I don't reproduce this error.
Could you send your VI?
Regards
VéroniqueD
NI France
(2,947 Views)
