LabVIEW crashes when Executed Query ( SQL )
I try to execute a stored procedure on our company server and all the time I execute the command LabVIEW crashes.
The good thing is, it only crashes when everything is working right. So i at least know i did everything right.
I tryed with sending the hard coded command and with creating parameterized query.
Is this a problem with our database or a known problem with labview ?
Greetings
Uwe
(3,568 Views)
Can you use highlight execution to figure out which node in the code causes the crash?
Cheers
(3,559 Views)
It crashes when it reaches "_Recordset Open" in Rec Create - Command.vi
(3,551 Views)
It's probably a problem with the ActiveX properties and methods that you're using and not related to LabVIEW at all.
I found this article that might help you try a few workarounds even though it wasn't a crash, just a delay.
This guy changed an input to True and fixed his crash when he was using the Open method of recordset.
Cheers
(3,538 Views)
