LabVIEW crashes when ending VI
Hi there
I've using some SSH libraries to create a terminal to comunicate with a RP board froms STEMlab. It works great, but, when I use de sequence to stop de VI, it aborts with no errors and then just crash down LabVIEW.
 Here I make a short video to show you how it works
https://youtu.be/U2Yfn8zyzi8
(3,271 Views)
I haven't looked at the video, as you say it "shows how it works", but it crashes LabVIEW, which I presume is not how it is supposed to work.  Do you want some help in fixing it?  Then please attach your code -- we can't "guess" what you did wrong.  Do not send a picture -- we cannot (easily) modify or test pictures.
Bob Schor
(3,220 Views)
And with the admin edit.  I would avoid that attachment.   Unless Kristi wants to add a note.
@Bob.... haven't we had this discussion?  I can guess... he wrote a bug maybe or found one perhaps.  Easy!
Yes, I have a badge for Troubleshooting LabVIEW.   Got it yesterday!
(3,214 Views)
I asked the admin to delete it because it was an upload of the Labwerx SSH libraries.
Bill
CLD
(Mid-Level minion.)
(3,189 Views)
Last year, I was running into issues with LabVIEW 2016 where it would crash if I did not properly shut down the SSH .NET library, which I am pretty sure the Labwerx library uses.  So make sure you are properly closing those references.  Do NOT use the Abort button.  Make sure you clear out any errors before attempting to close the references.
FYI, my case turned out to be I got an error in the middle of the application and the error caused the Dispose method to not execute, leaving references open.  This then crashed LabVIEW at some later point (don't remember the exact details of when the crash happened, perhaps on the next run or when I tried to close the VI).  This is why I recommend you make sure the errors are cleared before going into the close methods.
(3,181 Views)
