LabVIEW crashes when programmatically getting the dependencies from a large project
Hi all,
I am working on a LV application in which a project has to be created programmatically & its dependencies have to be analyzed. But when I add a source folder containing large number of files (>1000) LV crashes when getting the Dependencies reference (in the highlighted method in the image below). Is there a workaround for this issue? Also finally I will have to compile this entire code to Packed Project Library. Does it require any extra coding?
Priyadarsini S
(3,523 Views)
Accepted by topic author Priyadarsini
Do you save the new project before you try to read the dependencies?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,516 Views)
Hi Mike,
Saving a project before and after getting the dependencies solved the problem. I remember doing it earlier, but after your suggestion tried again and it did work great. Many thanks!
Priyadarsini S
(3,476 Views)
