LabVIEW crashes when you run a VI that contains a mixed signal graph with a multi-plot cursor.
Hello, LV 8.2.1 notes indicates the following bug fix:
43SAIR2A  Fixed an issue where LabVIEW crashes when you run a VI that contains a mixed signal graph with a multi-plot cursor.
I am running this version, and still have this behavior.  Is there anything I may be missing, and/or certain circumstances that may still be causing this?
thanks in advance,
Darren
(2,994 Views)
Darren:
I looked at the CAR ID that you mentioned and the issue has been resolved in LabVIEW 8.2.1. To verify something similar, I ran the attached VI and things worked just fine. Please feel free to send me the steps to follow to reproduce the issue you are running into in 8.2.1.
Rudi N.
(2,962 Views)
Thanks Rudi,
  Your VI works fine for me.  The crashing in my app has been intermittent, but did go away completely when I eliminated all muliplot cursors.  The graph I have is a bit more complicated, with analog and digital waveforms, multiple plot areas, and dynamic assignment of Y-scales.  It's in a larger app and not easy to extract now, but I will build a simpler version that hopefully demonstrates the behavior and post it up.
thanks,
Darren
(2,955 Views)
Darren:
Thank you for your response. I am curious to find out what else is differerent about your application that is crashing. I will wait to see a trimmed down version that reproduces the crash.
Rudi N.
(2,923 Views)
