LabVIEW driver for sony xcd-x710 camera
I was wondering if anyone has a LabVIEW Driver (version 8.2) for the Sony XCD-X710 camera?
(5,186 Views)
Hi Nika,
The Sony XCD-X710 Camera is a IEEE 1394 Firewire Camera, and the Vision Acquistion Software has the driver that you will need. It is avaliable for download here:
http://joule.ni.com/nidu/cds/view/p/id/1099/lang/en
This is the latest version of the driver and is compatible with LabVIEW 8.2:  http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument
Also, note that for the IMAQdx drivers that are used to communicate with your camera after 30 days the evaluation version will expire and you will be required to have a license to use them.
Cheers!
Marti C
NI Medical
(5,172 Views)
Thanks for the link. Another question: how can I alter the existing examples so that video taken by the camera can be saved to a file. I didn't see a VI that could do this.
(5,159 Views)
Hi Nika,
You can use the example called Grab and Save to AVI.vi found in Hardware Input and Output » IMAQ » File Input and Output. Just replace the IMAQ VI's with the ones for IMAQdx.
(5,145 Views)
TENGO UN CONTROLADOR DE VIDEO IMAQ PCI - 1409 DE NATIONAL INSTRUMENTS ESTA CONECTADA CON UNA FILMADORA SONY CCD-TR818 TENGO INSTALADO EL SOFTWARE NI IMAQ 3.0.1 DENTRO DEL SOFTWARE SE VE PERFECTO LA IMAGEN PERO CUANDO TENGO ENTRO AL SOFTWAR ANY-MAZE LA IMAGEN SE DISTORCIONA Y LA IMAGEN NO SE VE NITIDA DONDE ESTA EL PROBLEMA SI ME PUEDEN CONTESTAR ACA O SINOI MEJOR AL CORREO elpotro20@hotmail.com MUCHAS GRACIAS
(4,240 Views)
Greetings,
It seems that the matter on which you are posting is different from the topic's subject. As such, your issue will get a lot more attention if you create a topic. In addition, this is the English part of the forum, as such, it might not be understood by most other posters. Please go to the spanish section of the forum in order to get more aid on the matter.
http://forums.ni.com/t5/Discusiones-sobre-Productos-NI/bd-p/6170
I wish you a great day!
(4,219 Views)
