LabVIEW drivers for Newport 2010A tunable diode laser?
My group aquired a Newport 2010A tunable diode laser and failed to receive the labview drivers for remote control operation.  Does anyone have this software?
Message 1 of 8
(4,839 Views)
Hello SteenatUVA,
At this time, National Instruments does not have a driver for that device.  You might want to try contacting the manufacturer of the device, they may have one.  Also, there is a great tutorial, Using the Instrument I/O Assistant to Aid in Creating LabVIEW Instrument Drivers, found here, that may be helpful.
Good luck with your application!
Meghan
Message 2 of 8
(4,813 Views)
Actually I do have drivers for the EOSI Laser which is the same laser but from the time before Newport bought EOSI. However, I am missing the manual for the laser, so if you are still interested after all this time in the driver I can send it to you. Perhaps you could send me a photocopy of the manual in return?  Uli
Message 3 of 8
(4,539 Views)
All,
   Here is a link to a clean photocopy of the EOSI 2010 laser manual:
https://wiki.brown.edu/confluence/download/attachments/29406/Diode+Laser+Manual.pdf?version=1
   You can also Google it using "EOSI 2010 laser" and find the maual in the link that says: "EOSI tunable laser diode systems and accessories are guaranteed for a period .... the 2010 laser diode. The first method is more sensitive but requires both .."  Good hunting.
Sincerely,
John Zehnpfennig
U-Michigan Optics Lab
Message 4 of 8
(4,496 Views)
Dear John, thank you very much, Uli
Message 5 of 8
(4,486 Views)
OK. this is a long time ago, but maybe you still are there ... I picked up an EOSI 2010A like yours about a month ago pre Newport stock too and I also have a manual ... I am looking to both obtain said driver as well as the wavelength, grating and range of this device [sn00266] parameters ... can you advise?  Thanks Grant
Message 6 of 8
(3,731 Views)
presently I am not at my home institution and I would need to ask a collegue to dig out the labview drivers. But I am sure we do have them somewhere.
Concerning wavelength, grating etc.: Does this mean you do not have the specs sheet? It should be inserted in the manual.
Cheers, Uli
Message 7 of 8
(3,727 Views)
Cheers, Uli
Message 8 of 8
(3,727 Views)
