LabVIEW embedded ARM, SD card example
Hello ,
I am looking for simple LV example how to read/write to SD card (MCB2300 board). Could somebody help?
Thank you
Bilik
(4,304 Views)
duplicate post
You gave a solution mark to your problem in the other thread but asking same again why?
(4,302 Views)
tell me whether this help you
(4,297 Views)
there is written in 07/2007 this> Currently, we dont have any examples for SPI. But I will try and get you some help on this.
no, this link doesn't help
Bilik
(4,281 Views)
I pressed myself accepted solution accidentally for "LabVIEW embedded ARM, serial" and I do not find way back. Sorry for this.
The problem remains: I bought from NI ARM evaluation kit which cannot run serial example. I already tried it on two different PC, one is running LVembeddedfor ARM V1.0 second one V1.1. Hope the problem is in myself and not in bought HW&SW, but please help.
Bilik
(4,280 Views)
You can unmark it by selecting from "Options" menu located at the top right corner of that post.
(4,278 Views)
