LabVIEW equivalent of Array[i].ClusterElement = Value
I have an array of clusters, which are composed of mixed data types (booleans, numeric, string controls). I would like to write a value to a particular cluster element of a particular array member.
If I right-click on that element and then create a writable property by going to Create->Property Node->Value then for some reason it always refers to the first array element even though I made the property node from, let's say, 4th element.
So how do I write to a particular place in my data structure? In other words, what would be an equivalent of C's assignment operator Array[i].ClusterElement = Value ?
(3,689 Views)
Accepted by topic author depswa
Use an In-Place Element Structure to index the array element. Bundle in the value to the element you want to replace. This could be a SubVI. You could build a SubVI for each cluster element or look into creating a Polymorphic VI.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
(3,674 Views)
Thanks a lot, pangvady. I though I would have to use references and "To More Specific Class" operators, but it turned out to be much easier.
(3,646 Views)
