LabVIEW for MacOS Evaluation
I'm trying to access an evaluation copy of LabVIEW for MacOS. When I go through https://www.ni.com/trylabview , I can only download 2019 SP1 Patch, which is not helpful since I need 2019 SP1 in order to apply the patch. When I select 2019 SP1, the Download button gets grayed out and I am presented with a lock icon below the button with the following message: "Previous versions are available only to customers with an active standard service program (SSP) membership. Purchase or renew SSP to access locked versions."
I understand if this is used to lock out previous versions of the software, but 2019 SP1 is current.
(2,795 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NaESAU&l=en-US
Check this article and see if that helps download the evaluation for Mac. The article has a direct link to the download of the trial version.
(2,697 Views)
