LabVIEW for pure DC Home Energy Management System
I am planning an off-grid Zero Energy residential Building made from a shipping container. The building will have a PV array and battery storage. The goal is that pumps, fans, heat pump, lights, fridge, slow cooker, computer and water heater all be DC powered (12 V system, except heat pump which will be 48 V). I plan to use a MPPT charge controller. I want to be able to control and monitor the energy system with a Building Energy Management System (BEMS). I think existing BEMS solutions may not be suitable for this research project, since it is a DC system with components from different manufacturers. Would LabVIEW be suitable to display and log the PV production, battery charge status (communicate with a Battery Management System), turn on and of equipment like lights and set up schedules and conditional rules for powering on/off equipment? Do you have recommendations for hardware, like energy meters, that I can connect with LabVIEW? I suppose I also need a hub that is connected to the computer. Is wireless solutions much more expensive than a wired system?
(3,602 Views)
Accepted by topic author audunbul
Hey audenbul,
Your question is fairly general. If you are considering an Embedded Monitoring Application look into how the RIO platform can be used (there are wireless options).
https://forums.ni.com/t5/Projects-Products/Design-Implementation-of-a-Building-Automation-System-Wor...
Hope this helps. If you look further into it and have specific questions let us know!
Rebecca
(3,531 Views)
