LabVIEW for remote monitoring of HYDACLab?
HYDACLab has a 4-20ma output that is sequential. Four types of data are output from the HYDACLab in a sequential order on one channel:
Start: 20ma for 2s
Pause: 2s
Signal 1: 12ma +/-8ma for 2s
Pause: 2s
Signal 2: 2s
etc...
Is this type of input manageable by LabVIEW?
(2,995 Views)
LabVIEW -- no.  LabVIEW has no ability to read any voltages.
You need instruments to do that.  So the real question is ... What kind of instrument should I use?  or Will (such and such) work?
Once you have the right instrument, LabVIEW should be able to handle your list without any problem.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,976 Views)
JBPowell
If you want to find the right DAQ device for your mesurement go to NI.com/DataAcquisition and enter the facent at the botom of the page. You can select current for measurement type and you may want to start with a USB device. You will be able to read any of these devices with LabVIEW.
(2,965 Views)
