LabVIEW formula to LaTeX format Converter
Does anyone know if there is a VI available that will convert a LabVIEW formula to LaTeX format?
e.g.
(a1+a2)/2   ---->    \frac{a1+a2}{2}
I wanted to check if something like this is available before venturing off and attempting to make my own.
(5,631 Views)
This shows the reverse direction, which might give you a push in the direction you want - http://decibel.ni.com/content/docs/DOC-13859
___________________
Try to take over the world!
(5,621 Views)
Don't know if this will help, but Darin did some incredible work with his "Math Node" (http://decibel.ni.com/content/docs/DOC-13859).
EDIT: Writing post while tst responded. Sorry for the double-answer.
(5,617 Views)
Thanks guys, I have taken a look at Darin's example earlier this week and did find a few helpful things, but like tst mentioned, its in the reverse direction of what i'm looking for.
(5,606 Views)
I did some work on faking LaTeX in that program. I parsed the known functions but did not convert the solidus to fractions. I can try to help if you head in that direction, and I am sure I have a lot of the code in hand.
(5,596 Views)
Yes, I would really appreciate that. Right now I am looking to write something that will convert just basic math functions (add, subtract, multiply, divide and maybe exponents). That should be good enough to get started for now. I'll see what I can come up with...
(5,585 Views)
