LabVIEW freezing while VI is running
I am not really sure this is the right place to post this, but I have run into a bit of a problem with a VI that I am making and I am pretty stuck. Basically the VI controls flow of a couple of gasses and their concentrations. When the VI runs for a long time, usually > 30 hours, it will just completely lock up. I checked Task Manager to see if there was any large memory or cpu usage, but everything seemed normal.
I attached the VI, and would be very appreciative if anyone could take a look and point out anything that looks funny.
System:
Windows 7
LabVIEW 2015
cDAQ-9174 with NI-9263 and NI-9205 modules
Sam
(5,240 Views)
You are endlessly growing the waveforms near the top of the loop.  It looks like you are putting in a new sample every half second.  So 7200 per hour.  216,000 samples after 30 hours.  Maybe that's not too much, but it sure seems like a lot of data to be accumulating.
I'd recommending getting rid of the DAQ Assistant and use regular DAQmx functions like you used elsewhere.
(5,218 Views)
Accepted by topic author slines
I am not seeing a reason to accumulate the data with the Build Array.  Just use the chart and it keeps a history for you.  If you want to see more data, either increase the number of samples it stores and/or use a Producer/Consumer to log the data in another loop and view the data later.
But that Build Array is definately your problem.
(5,185 Views)
Thanks for the reply. I made these changes and it seems to be working now.
(5,082 Views)
