LabVIEW - including image folder in executable
Hello all,
The current LabVIEW directory I'm working on uses an image folder to load images of our products in the application. There is no real problem with the solution, it works fine. However, I don't like the fact that we'd send the software to clients with an images folder that they could access or even just see.
Here's what it looks like currently.
Is there a way to include this images folder in the executable or the installer of the project  so that it doesn't show by itself ?
(3,777 Views)
Hi Frogeur,
You could convert all the images into 2DPicture constants, and place them in a "collector" VI to access them...
(3,772 Views)
Thank you for your asnwer, I've looked up ways to create 2D picture constants and only found this video : https://www.youtube.com/watch?v=UPqL8otrMAo. However, it looks like a convoluted way to do it. I've looked around the VIs palette and only found the "2D image" VI which looks to be more about drawing shapes than stocking a picture.
How would you create said picture constants ?
(3,654 Views)
Accepted by topic author FrougeurPro
Hi Frougeur,
Like this:
(3,649 Views)
Ok thanks, that's how it was done in the video but I thought there might be another way to do it.
Thank you for your answer.
(3,644 Views)
Hi Frogeur,
Sure there are other ways.
You might employ VIScripting to create those constants from image file: this way you can create constants (and any other code) programmatically!
(3,639 Views)
