LabVIEW installation directory
I do not have enough space on my C memory so i would like to install LabVIEW on my D memory. Unfortunatelly i can not find a way to choose installation path. I had written to support and they have sent me screen, which i attached. In their massage they recommended to download a version which can be installed online without NI Package Manager (programm which does not allow to insert an installation path). After i downloaded it, mounted .iso file and disable internet connection NIPM showed anyway and i could not choose my path.
Has anybody found a solution to my problem?
(2,264 Views)
Given that LabVIEW has a complex installation and "operation" system, with lots of files stuck in lots of places, with a "still-in-active-development-Installer-and-Bottle-Washer" called NIPM in charge of it all, it makes much more sense and is much more probable to succeed to either debulk your C: drive (for instance, by moving most of your Profile to another drive, or buying a larger drive and "cloning" your C: drive to the larger drive) than to try to install LabVIEW to, say, D:.  It might work now, but there's no guarantee that NIPM 2021 will be happy ...
Bob Schor
(2,231 Views)
