LabVIEW installer issue
Hi all
I have created a installer in labview(). When I tested in labview installed PC. It is working fine. But when I try it in a fresh PC. I have created installer by adding runtime, max and ni visa toolkit.
when i try to run that exe, it showing error "the program can't start because cvirte.dll is missing from your computer. Try reinstalling the program to fix this problem."
when I searched it in ni website, it is showing labwindow/CVI. Which I didn't used in this application.
Please suggest to resolve this problem
phani srikanth
(3,112 Views)
Accepted by topic author PhaniChillara
Are you absolutely sure the CVI runtime engine is not used by any components of your program? That may be some libraries you use, while I would say such situation is more typical for TestStand, not for LabVIEW. Try to include cvi runtime in your installer and see what will happen.
(3,107 Views)
yes it working fine now. soory i am using a dll which is developed in lab windows.
thanks
phani
phani srikanth
(3,072 Views)
