LabVIEW load error code 3: Could not load front panel
Thanks for giving a try RMathews.
I Re-developped the VI.
Message 91 of 178
(4,040 Views)
Dear Houssam,
I've done everything I can with with NI will allow me.  With my lowly student edition though, I don't have a whole lot of pull, and my options are nill.  If you could fix my file, I would be so grateful.  I'd rather not ask/intrude, but at this point it's the only option I have.
Anyhow, I've attached the file that I've been unable to open.  If you can help, that'd be great!
Carson
Message 92 of 178
(4,020 Views)
HI Carson,
I didnt had any problems to open your vi. I copied the blockdiagramm to a new one.
Generelly I think it would have been faster to reprogramm it at all as it is a quite small one Smiley Wink
Here you have in the LV version 2010 as I didnt know which version you are using.
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 93 of 178
(4,016 Views)
Ah Thank you so much.  I realize it's not a very big VI, but I've not been using LabView long, and was afraid to try and reprogram it in 2011.  Plus, a friend of mine couldn't get it working in 2012 or 2013, so I just wasn't sure.  Either way, I sure appreciate you taking the time to fix it for me RMathews.
Message 94 of 178
(4,013 Views)
I'm having the same issue, though the aforementioned methods don't work (LV2012f3 Dev).  Could someone fix this file please?  Thanks very much in advance!
Message 95 of 178
(3,997 Views)
Hi RMathews,
Could you please send me your mail so I can send you my VI?
I'm also receiving the Error3 - error code.
I'm working with LabVIEW 2009 and tried the given solutions of this topic, but nothing works 😞
Thanks!
Message 96 of 178
(3,956 Views)
HI
Jeanuis, I couldnt fix your VI neither - sorry.
lderijck - for personal assistance please contact you local NI branch, or download the evaluation version of LabVIEW 2012 SP1 (http://www.ni.com/labview/) and try the solution posted in this forum post.
Cheers, RMathews
Ramona Lombardo
Message 97 of 178
(3,945 Views)
RM,
Tried submitting it, evidently there are header errors in the file that couldn't be fixed.  Just ended up rewriting it, thanks for the attempt though!
Message 98 of 178
(3,936 Views)
I had this same issue.  In my build Source File Settings I had to unclick the Use default save settings.  Even though it looks like the remove from panel is not checked.... anyways this fixed the issue for me.
Message 99 of 178
(3,885 Views)
hi there, hi RMathews,
I couldn't imagine that such an error may occur and make a VI totally corrupted... And so, I know now that backup is highly recommended !
I tried the solution posted above (connPaneRecoveryMode=True), but I wasn't able to open my VI (on Labview 2012). I also downloaded the evaluation version of Labview 2012 on another PC, but it was also unsuccessful.
I would be very grateful if you could try to fix my VI ! It would save me a lot of time !
Thanks a lot !
Cheers, Olivier
Message 100 of 178
(3,813 Views)
