LabVIEW load error code 3: Could not load front panel
Hi Gerd
Thanks for the reply.
I don't know why that didn't work.I had to rewrite the code again.
Now the error doesn't occur again.
Regards
Denesh
Message 161 of 178
(3,425 Views)
Open in LabVIEW 2018, but was missing subVIs. Back saved a version for you if you still need it.
mcduff
Message 162 of 178
(3,416 Views)
Thanks!
Regards
Denesh
Message 163 of 178
(3,415 Views)
Hello all
I have one LabVIEW library  when I try to open the VI's in Library it is showing LabVIEW load error code 3: Could not load front panel(VI library), I will attach the  file which I am using for my work can anyone please go through this and suggest me the steps to solve this issue. It will be a great help to me
 I am using LabVIEW 2017 and the LabVIEW library which I have attached is downloaded file from online
Thank You
Message 164 of 178
(3,356 Views)
The files seem to be corrupted.  Were you ever able to open them?
If not, contact whoever's site you downloaded them from.  Or try downloading again.
Message 165 of 178
(3,349 Views)
Hello
No, I am not able to open the files , I downloaded this from online
Thank you
Message 166 of 178
(3,353 Views)
Dear all,
I have a same problem. If I want open .vi there is an error: "LabVIEW load error code 3: Could not load front panel".
I'm using LabVIEW 2019 SP1. I tried add connPaneRecoveryMode=True to .ini , but it is not working to me.
Could somebody help me and recover attached VI, please?
regards,
Message 167 of 178
(2,880 Views)
Try this!
Did you ever heard of SCC? Using a SCC tool you can easily recover older revisions of your sorce code!
Btw. you really should think about refactoring that VI:
The white background shows a FullHD screen…
Message 168 of 178
(2,873 Views)
Thanks for the quick help.
SCC says nothing to me so far.
Which SCC tool can you recommend for Labview or do you use for recovery?
Yes, refactoring is mandatory, but here again it was about a quick development of a prototype with several new functions.
Message 169 of 178
(2,848 Views)
Hi Rig,
See Wikipedia
Message 170 of 178
(2,843 Views)
