LabVIEW makerHub and arduino
Guys I am using Arduino UNO and wind sensor. I need to show wind speed and temperature. I did that with LINX and its working good, my problem now is, results showing pretty slow, can anybody help me what I need to change in my program to work good and to show results fast on the thermometer and waveform chart. I am upload my block diagram.
Thanks.
Message 1 of 8
(6,401 Views)
I should state that I am not familiar with the specifics of how Linx works.  But I would start by using the Read N Channels to read both channels in the same call.  This should reduce the transmission overhead and speed things up.
Message 2 of 8
(6,376 Views)
I did now with read N chan. But its still slow... Do you have any idea what should I do with this to show results fast on thermometer and Waveform chart ?
Thanks.
Message 3 of 8
(6,354 Views)
Define slow. Have you tried the LINX forum?
Message 4 of 8
(6,329 Views)
When I am running program things about LINX working good I think so..
I think those numeric operators making things slow, so is there any way to make this calculate faster and then I think results will showing much faster on the front panel. I need to show every second on front panel about wind speed and temperature. I hope so I explain good what I need.
Thanks.
Message 5 of 8
(6,315 Views)
Accepted by crossrulz
Turn OFF highlight execution (the lightbulb in the toolbar).  That is a debug tool that slows your program to a crawl but shows you values as they are performed.
Message 6 of 8
(6,291 Views)
Your current VI runs as fast as it can and the operations are not going to be a significant delay. You still haven't explained the actual time it takes without highlighting mode on. Look at the sketch to see what is done.
Message 7 of 8
(6,284 Views)
Oh my God ! Thank you a lot ! Its working now !
Spoiler
Smiley Embarassed
 I am just needed to turn OFF highlight execution ! lol
Message 8 of 8
(6,274 Views)
