LabVIEW, myDAQ, Bode plot
There are "only" two error
Message 21 of 24
(3,487 Views)
Accepted by topic author PetraGergely
If you run this VI, what value do you see in the Data size indicator? Also, do you see the two curves in the XYGraph?
Message 22 of 24
(3,479 Views)
I'ts working. Smiley Surprised Smiley Happy
Thank you sooooo much! This is I want to see. I'm so happy now.Smiley Happy
Thank you again for your patience and understanding. 😄
Message 23 of 24
(3,473 Views)
If my last VI worked for you, then you can mark that post as solution, so it helps to others in the future dealing with similar setup. Good luck with your project, and come back if you need further help.
Message 24 of 24
(3,469 Views)
