LabVIEW native functions - reentrant or not?
Are LabVIEW native functions treated as reentrant or non-reentrant? This would be with respect to Queue Operations (Enqueue Element, Flush Queue, etc.)
(4,673 Views)
All functions with yellow icon are reentrant.
George Zou
(4,655 Views)
A very large majority of my projects would not work if they were no reentrant.  As already said, all of the primitives (yellow nodes) are reentrant.
(4,634 Views)
While for the most part yes but for some reason I think there is some very low-level something that is used by the queue functions that is special.
The term "atomic" comes to mind but I'd be darned if I can recall what the story that goes with that memory.
To the original poster of this question...
What prompts you to ask?
Ben
(4,626 Views)
Ben,
Thanks for the info. I'm currently working on an application that runs on a test system for a medical device manufacturer. This test system uses 2 - NI PXI-7811R FPGA cards to service 12 test insertions at one time. Therefore, 6 instances of the application will use FPGA card #1 and the other 6 instances will use FPGA card #2. The way the application is structured, most of the upper level VIs are reentrant, but the lower level VIs that interface with the FPGA cards are non-reentrant. A semaphore is used to handle the queue for the FPGA card.
I'm picking up the code where others have left off, and am reviewing for proper reentrancy settings. I encountered an issue where an upper level VI is reentrant, a sub-vi called from there is non-reentrant, and the native LabVIEW functions the sub-vi calls are apparently reentrant. This seems like bad coding practices to me - I believe there should be a point at which it should transition from reentrant to non-reentrant, but not switch back and forth.
Sorry for the long drawn out response, but that's why I asked....;-)
(4,598 Views)
Also, does anyone know of a users guideline for reentrancy settings?? Thanks!
(4,595 Views)
@pelaid1 wrote:
Ben,
I'm not sure what you mean by "switching back and forth".  It seems to me that it is very well defined.  Stuff you make is non-reentrant by default, while native LabVIEW nodes are reentrant.  I do understand that it is frustrating that just one non-reentrant thingy in your reentrant VI suddenly makes the VI behave unexpectedly (but adhering to dataflow principles), though.
Bill
CLD
(Mid-Level minion.)
(4,585 Views)
