LabVIEW no robotic palette
I'm doing a robot project by using LabVIEW and MyRIO. I've installed the labVIEW for MyRIO with all the optional installations, which includes the robotic module. Eventhough, so I can run Dynamic A Star example in example finder, when it comes to that I want to build my own maze, there is no Robotic palette in Funiction palette.
Could you help me to solve this problem?
(3,483 Views)
Navigate to the Pallette and click the thumb tack icon to pin it, or add the subpallette to favorites for quick access.
(3,479 Views)
If you can open an example that uses the robotic functions you should be able to use detailed help for one of the functions and "Find on palette" to open the palette. Once you know the name of the palette you can search for it in your own project or do as ijustlovemath suggested.
A Johnson
(3,429 Views)
