LabVIEW on Solaris - how do I call a shared library
Hi all,
I am a long time user of LabVIEW and have written dll's that I have called
in the MS Windows versions, well now I have an application I am porting to a
Sparc Ultra 5 running Solaris 7. I just installed LabVIEW 5.1 with the
Application builder and everything works great ! Problem is now I have one
win32 dll I need to re-create as a shared library on the Sun. I can't seem
to find any good app notes or references on how to do this. WIll the GNU
C-compiler work ? Would any one be willing to post an example piece of code
with the proper function call layout and header file, or point me in some
useful direction.
Chris
(3,258 Views)
> useful direction.
The easiest way is probably to follow the examples for CINs and shared
libs. I'm pretty sure gcc works, and there aren't nearly as many an
noying
incompatibilities on SPARCs because the calling conventions are dictated by
the HW rather that the OS; so there is one standard instead of three or four.
I don't have the manual in front of me, but I think there are detailed
instructions for building libraries on the different OSes.
Greg McKaskle
(3,258 Views)
