LabVIEW opens new blank vi when attempting to exit
@Jeff-P wrote:
Unfortunately that fix did not make it into 2012 SP1. I have PMed you the fixed version and the instructions for installing it.
Got it - thanks Jeff.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 11 of 20
(2,155 Views)
Jeff P,
That little patch would be nice to have on hand.  Would you mind PMing me as well? Thanks.
Message 12 of 20
(2,137 Views)
You should have it now, let me know if you weren't able to get it.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 13 of 20
(2,127 Views)
Got it
Message 14 of 20
(2,122 Views)
I am having the same issue.  Could you PM me also?
Mark Yeager
Message 15 of 20
(2,090 Views)
Mark,
I just sent it to you, please let me know if you are unable to get it.
Jeff Peacock
Message 16 of 20
(2,073 Views)
I just observed the behavior for the first time.  Ctrl+Q (File>>Exit) breaks the loop
Message 17 of 20
(2,019 Views)
Hi Jeff,
Did you run into the issue after replacing the Getting Started Window with the version that I sent you, or was this on a computer that did not have the updates Getting Started Window?
Jeff Peacock
Message 18 of 20
(2,003 Views)
The machine I ran into this on does not have the updated Getting Started Window.  Straight up LabVIEW 2012 (12.0f3 32bit)
Message 19 of 20
(1,998 Views)
CAR 386855 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Message 20 of 20
(1,960 Views)
