LabVIEW possibilities for Android and embedded systems
Dear Sir or Madam,
We are building some test environments based on your software and now we have came into discussions about future possibilities with LabVIEW. As there is a lot of information available we are getting a little bit confused about what we can do and what not with our current software. Now we own the "LabVIEW full development System for Windows" and we are interested in analysing the possibility of buying your application builder. The problem is that we would like to address, at least, two different issues with LabVIEW:
1st: we want to build controllers and self executable applications that work in Windows, Linux, MAC and Android. I've read many possibilities on the internet about LabVIEW but I'm not sure about what systems are officially supported, so: Is it possible to build Apps for these three systems from the Windows App Builder? Is there support for Android? Do Linux Apps run with Android?
2nd: The second issue is to embed LabVIEW into small microcontrollers to deploy our custom System managers and controllers. Is this possible? I've seen the ARM toolkit but I am not sure about what functionality of LabVIEW is available there. Can all the functions be used? Can it be customized to any device that is ARM? Is it possible to port to non-ARM devices or DSPs???
Thanks in advance.
(3,062 Views)
You would probably be better off talking to your local NI rep.  Clicking the contact NI tab at the top of your browser would be a good place to start if you do not know your local rep.
(3,043 Views)
