LabVIEW print data by using DOT MATRIX printer?
How to program in LabVIEW such that certain data can be printed out from dot matrix printer?
p/s : The dot matrix printer(EPSON-TM - U220) is connected to computer via serial port.
Thank you very much for replies...
(5,695 Views)
You use VISA functions to communicate with the serial port.
Search the example finder for "serial".
(5,694 Views)
I coudn't run my serial examples in LabVIEW although I have connected the dot matrix printer to my computer.
(5,660 Views)
What do you mean?  Did you get an error message?  Did the PC crash?  Did the printer go up in flames?
(5,657 Views)
Accepted by topic author KitChongYue
I found the solution~
preset the dot matrix printer as dafault printer and use an icon in LabVIEW called - Easy Text Report will do.
😃 Thank you very much for your reply!
(5,646 Views)
Occam's razor.
Ben
(5,622 Views)
