LabVIEW project
Hi! I was given a project called design and implementation of medical ventilator automation using LabVIEW and IOT. I was unable to get output, tried so many times and couldn't construct exact circuit in LabVIEW. Please help me with circuit diagram.
So I was asked to include sensors like temperature, pulse oximeter and carbon dioxide sensor. Based on the oxygen level of the patient obtained through pulse oximeter, I was asked to give 2-3 constrains like(if the patient oxygen level is 90% required amount of oxygen cylinder valve has to open automatically).
(1,699 Views)
Is this homework?
You talk about circuits which are electrical constructs.  But you want to do something in LabVIEW which is software.  The code in LabVIEW is called a block diagram.
If you weren't able to do what you wanted, why don't you attach your VI so we can see what attempt you have made.
(1,687 Views)
Yes! It is one of my undergraduate project. I am sorry that is BLOCK DIAGRAM.
(1,679 Views)
You didn't attach your VI so we can see where you are stuck.
(1,653 Views)
