I have a pretty complicated VI - with 2 problems.
1. There is one sampling option which when used causes LabVIEW to quit. No warnings, no nothing. Just suddenly disappears from the process list and the screen.
2. When I use a different sampling option the VI samples but then hangs with "LabVIEW.exe has generated errors and needs to close. An error log will be created". The computer then restarts. I can't find the error log anywhere.
Does anyone know what might be creating those errors, or alternatively where the error log can be found? I'm not using anything fancy like ActiveX.
