LabVIEW "List Folders" function alphabetical sort not same as Windows Explorer
Hi all
The "List Folder" function does not list filenames in the same order as Windows Explorer (Windows XP, LabVIEW 2009SP1)
 (see attached).    Anyone else experience this?   Just wanted to check before writing code that works around this
Regards
Vijay
Message 1 of 10
(9,765 Views)
NIExpert wrote:
Hi all
Regards
Vijay
In my experience, True!
Ben
Message 2 of 10
(9,753 Views)
What you are seeing is that the OS looks a little deeper into the filenames. This started with XP. Numeric sequences are considered and sorted with lowest values first. LabVIEW uses strict ASCII sorting. Thus, in your case, the two files "Att_0o5dB.xls", and "Att_0o25dB.xls" would have "Att_0o5dB.xls" listed first by the OS because 5 is smaller than 25. However, LabVIEW would list "Att_0o25dB.xls" first since the ASCII value of 2 is less than the ASCII value of 5.
I'm not sure, but I think, for instance, Linux uses ASCII sorting. Not sure about OS X.
Message Edited by smercurio_fc on 05-17-2010 01:38 PM
Message 3 of 10
(9,729 Views)
Hello all .
I am using labview for reading waveform files and I have the same problem and need to read in waveforms stored in a txt file in sequence , problem is that they are ordered as follows
G:\Tests\Test 2\Waveforms\t2_1_1_14536301.txt
G:\Tests\Test 2\Waveforms\t2_1_2_18270829.txt
G:\Tests\Test 2\Waveforms\t2_1_3_22851419.txt
G:\Tests\Test 2\Waveforms\t2_1_4_22934557.txt
If Labview was to reading the filename found in the folder it would order them in the order of the biggest down to the smallest , I built this VI to fix the problem its only basic as I am still new to LV but it dose the job for me , If its any use to anyone else please find attached
Rob
Using labview since LV 8.6 , Great Stuff 🙂
Message 4 of 10
(9,617 Views)
FYI, just because it is related, I have attached a VI which alphabetizes a 2D array. Saved to 8.2.
Richard
Message 5 of 10
(9,594 Views)
Thanks ,
That will sort the problem with the second set of files I have from two cameras !
Cheers
RobSmiley Happy
Message 6 of 10
(9,582 Views)
hi all
Actually I am trying to import several image files to my Labview program but I want to specify the folder instead of importing image at each time.
I highly appreciate if any could help me
thanks
Mori
Message 7 of 10
(8,664 Views)
This sounds like a different question than what was originally asked in the thread.
To get help, you'd be better off posting your question as a new message thread.  And please provide more detail in your question.
Message 8 of 10
(8,657 Views)
Mori,
I would agree with Raven a new thread and more info please, but just to put what I think you are looking for into the reply I think what you are look for is the Recursive File List.vi. Its found in Programming>>FileI/O>>Adv File Funcs>>Recursive File List. This vi will give you the array of paths in the folder so just use the array of paths and programmatically open the image do your analysis and open the next one and so on .....
Hope this helps
Rob
Message 9 of 10
(8,563 Views)
Thank you
you are right, I create a new threat,
http://forums.ni.com/t5/LabVIEW/Automatically-import-image-files-from-a-folder-to-Labview/m-p/169599...
you hint is very helpful for me,
Message 10 of 10
(8,536 Views)
