LabVIEW readings from a DMM too slow
Right now I am working on a program that takes readings from a multimeter and puts them into a graph. The multimeter is taking readings at 100 per second, while LabVIEW is only taking a number from the multimeter every five to six seconds. I am very new to LabVIEW so I am not sure if there is something in my program that is slowing it down or something that I can add to increase the frequency of readings taken. I have attached the program file I'm using and the multimeter is a Tektronix DMM4020, though I don't think the problem is with the multimeter. Any advice would be great, thanks in advance. Rach
Message 1 of 14
(4,258 Views)
Can you post your code so taht we can see if it is a code problem or limitation oh the communicatin protocal. How are you takling to this device (GPIB, USB, RS 232 etc...)
Tim
GHSP
Message 2 of 14
(4,257 Views)
The device has an RS-232 port to usb cable for the PC. I'll try to attach the code again, it didn't attach the first time for some reason.
Message 3 of 14
(4,248 Views)
It's still not working
Message 4 of 14
(4,247 Views)
Attaching files is restricted to certain file types. Maybe you do not meet the filter? (if not, try to zip the files first!)
Additionally, there was an issue in this forum that previewing the post removes all attachements. Maybe, this issue is still present....
Norbert
Norbert
Expert: Geometry
Message 5 of 14
(4,240 Views)
I've tried uploading the file in a zip folder, renaming the file, and taking a screen shot, and none of them will attach. Is there a way to change the block diagram to written code so I can paste it? Or should I just try describing it?
Message 6 of 14
(4,231 Views)
Do you get any error message when browsing your attachment? Is there an error when posting a message with an attachement? If so, what is that error?
I find it possible, that you have either a firewall or virus scanner active preventing you from attaching files. Please check that.
thanks,
Norbert
Norbert
Expert: Geometry
Message 7 of 14
(4,227 Views)
There is no error when I am browsing, trying to attach, or post something that should have an attachment. It simply reloads the post message page I am writing on and the document is still in the browse box unattached. I tried removing the firewall temporarily and it still will not attach to the message.
Message 8 of 14
(4,224 Views)
I think they attached.
Message 9 of 14
(4,215 Views)
They weren't posting through Mozilla Firefox, it worked through Internet Explorer
Message 10 of 14
(4,212 Views)
