LabVIEW signal express 2012 compatibility with LabVIEW 2016
I want to convert a VI from LabVIEW signal express 2012 to LabVIEW 2016 so, is that possible?
(2,791 Views)
My Distribution Kit for LabVIEW 2016 ships with Signal Express.  If you install 2016's Signal Express, it will probably "accept" the code designed to work with LabVIEW 2012.  The ReadMe contains the following:
Application Software Versions Supported by SignalExpress
LabVIEW 2012 (32-bit), 2013 (32-bit), 2014 (32-bit), 2015 (32-bit)
Bob Schor
(2,759 Views)
