LabVIEW support library does not edit!!
I've created a support library using the new project manager in LV 8. When including the support library in my project, I can edit the support library. But, if I open the support library directly and try to edit it (add VIs, etc.), the changes do not save. My colleague duplicated the behavior. It is either a bug or a serious misunderstanding on how the project manager works. Am I missing something??
(2,891 Views)
Hello!
I tried this out, but had no problems with editing the library within the Project Explorer or editing it directly. Changes will be safed in both cases. Maybe you changed to different libraries with the same name. You can check this out by checking the libraries path under the properties of the library (right click on the library).
Following a link for more information on LabView Project Libraries:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2vlCAA&l=en-US
Kind Regards, Christian
(2,866 Views)
