LabVIEW sure loves to crash for stupid reasons.
Regarding LabVIEW crashes....,
Depends on your definition of "crash".
We suffer regular problems with the IDE, but we're very often running multiple targets at a time (RT, Windows, FPGA) where we are deploying current code and running it.
Deadlocks and hangs are something that occur every day, mostly multiple times a day. One trick I've found recently is to put LabVIEW on a single core for 30 seconds and then switch back. This has saved me from having to stop the process on multiple occasions.
As per usual, I think the management of the compile cache is part of the issue. But we're not going to go back from that, it offers far too many benefits with regard to SCC.
Message 31 of 40
(2,490 Views)
I have these (almost) deadlocks regularly. But it is not limited to LabVIEW. What I have found as common nominator in every case is VmWare. It's not a total deadlock in the sense that sometimes other applications keep working for a little while but eventually completely freeze too. That includes Teams, Chrome and other applications. And after 30 seconds or sometimes a minute, all the applications suddenly refresh and everything is back to normal. Without VmWare active, I have not encountered these lock ups yet, but I work a lot with VmWare so not sure this is a significant indication. Once this starts not even Ctrl-Alt-Del seems to make a real difference. Once everything comes back it will then switch to the lock screen that you get with Ctrl-Alt-Del, but usually that doesn't happen immediately.
Rolf Kalbermatter  My Blog
Message 32 of 40
(2,478 Views)
Rolf, you get a full system lockup? I only ("only") get a full LabVIEW IDE lockup.
I also use Virtualisation a lot.... must investigate going native again.
Message 33 of 40
(2,456 Views)
Not immediately. One application starts to freeze (usually LabVIEW as that is were I work most in) then I try to switch to another, that still seems to work for a few moments, and so on until every window on the system is frozen. Usually all the VmWare windows freeze first, then the rest. Then I can wait. Somewhere it returns to normal after 30 seconds or a minute, sometimes I get impatient and press Ctrl-Alt-Del but even that usually doesn't immediately react. Then suddenly every window on the system refreshes in a frenzy and everything seems back to normal, with the lock screen enabled if I was impatient enough to press ctrl-alt-del. Sometimes I simply go and fetch a coffee and by the time I return, things are usually back to normal.
Message 34 of 40
(2,452 Views)
Sorry to harp on about this, but some aspects of this sound really familiar. We've essentially given up on finding out what exactly is causing it, hence the interest in any similarities to what we see.
The "refreshes in a frenzy" is something I see with LabVIEW regularly also without virtualisation. We call it the "LabVIEW shuffle" because the Z-order of the LabVIEW windows after this seems kind of random. I'm not sure that aspect is purely virtualisation-related.
Freezes and the like I have also observed in native windows and virtualised. It may be more often virtual, but since I don't work native much any more, that may simply be skewed by usage time.
Message 35 of 40
(2,437 Views)
I can't really comment on the refresh disturbing the Z order very much. I have a compulsive disorder that makes me close windows more often than not, so I seldom end up having lots of VIs in LabVIEW open. Altogether there are usually several applications open however, including one or two browser windows with usually several tabs. Outlook, Teams, Notepad++ and sometimes Excel or Word belong to that list too. And they are all affected, although often they seem to all still be kind of responsive for a short while when that condition occurs. I've tried various things including tweaking the VmWare settings but so far I haven't found anything that seems to make a definitive difference.
Message 36 of 40
(2,407 Views)
Yes this is it, same lockups and crashes with the IDE
Message 37 of 40
(2,369 Views)
Yes, that definitely happens when running on a native OS. I assume that's more of a LabVIEW bug. I'm guessing LV or Windows sees the freeze and tries to do a kind of reset (maybe they're then ordered by window title or handle, but I never tried to figure out the new order).
___________________
Try to take over the world!
Message 38 of 40
(2,313 Views)
That's probably a good guess. A Windows application needs to continuously call the GetMessage() Windows API function in a loop to query for new events (mouse, keyboard, devices, OS, etc, etc). Windows has some monitoring logic in there that detects if an application is still calling this function regularly. This loop runs in the LabVIEW root loop and main thread. And Windows did not like this function being called from different threads so this design was mandated. I suppose that the Windows NT API since has been made fully threading save even here, but that will certainly come at a cost as there will be semaphores and/or mutexes to protect this and there would be some performance decrease if these functions were not called from the same main thread all the time.
Anyhow, Windows will usually redraw the window frames of an affected application in a shaded color when it detects that the processes main window loop has stopped calling this function and eventually post the message box that the application has been getting unresponsive and you can wait if it returns or abort it. But it's likely that there are situations where it considers that a force redraw of all windows might be also an option.
But the lock I usually see goes a lot deeper and affacts sooner or later every single application in Windows. And knowing how deep VmWare likes to hook into Windows to do its thing, I can very much envision that one of these hooks is responsible, most likely with one of its device drivers that somehow gets in a mutual exclusion lock until the underlaying function to communicate between the host and the virtual client instances eventually times out.
Message 39 of 40
(2,299 Views)
Just now I had a freeze, LV 2019 in Virtualbox, simulated FPGA execution. COuldn't access any windows, UI was being updated, but input was blocked completely in LabVIEW. Mouse hover worked, but button presses were not being registered at all. An FPGA code was runing (simulated hardware). I couldn't stop it.
I managed, however, to start task manager and set LabVIEW to one core (Details tab) and responsiveness returned.
Message 40 of 40
(2,247 Views)
