LabVIEW system configuration VI Import
Hello, I have no problem exporting a NI Configuration *.ini file using the export configuration VI.  However when I make modifications to the ini file and then try to re-import the txt file the Import Max Configuration VI errors out.  I am using Labview 2011 with daqmx 9.0.  Any Ideas.
(2,953 Views)
Hi Wade,
I'm with Applications Engineering at National Instruments. Have you tried the same thing with a .nce file instead of a .ini? Are you using the same version of LabVIEW on the same computer to modify the .ini file? A little more information on your application would be desirable.
Basil
Basil
(2,918 Views)
