LabVIEW to control SFPDP using -SSH
I'm working on a project to control a SFPDP Recorder with LabVIEW using an -SSH connection to keep things simple. I am able to get logged onto the recorder which is Linux based, but after that none of the commands I send are accepted and LabVIEW gives me ERROR 2. Attached is the vi I'm using to connect to the recorder and I just expanded on the to send the command lines.
Message 1 of 1
(2,053 Views)
