LabVIEW upgradde issues Xp and NI-DAQ 7.3.1 application builder?
Old code, new application, finally attempting an upgrade to XP and LabVIEW 7.1.1, with NI-DAQ 7.3.1. Has there been any issues with LabVIEW 7.1.1 Professional Development suite and the application builder or with PCI-MIO- and SCXI harware? Issues we found in past DAQ upgrades with support file additions when using NT. The application has an Acquisition VI that does calibration and averaging then to a global and then to main application for further crunching, much like VI logger. Any advice on the 7.1.1 mass compile requirement would also be helpful.
(2,518 Views)
Hey Scott D.
If I understand well, you are just wondering if there are things that you should watch out for when upgrading? if so, search the discussion Forum at http://forums.ni.com/ or the knowledge base at http://digital.ni.com/public.nsf/MainPage?ReadForm&node=133020_US . If there have been issues, they are all referenced there.
If you have more specific issues you are thinking about, let us know.
Hope it helps...
Serges L.
(2,504 Views)
