LabVIEW w/ PuskOK Woes
I am using svn+ssh with PuskOK to connect to subversion server runing subversion-1.4.3-2.fc6.
I am connecting to this server through LabVIEW's Project Explorer which is setup for PushOK using SVN.  I browse to the file I want to add to the module I created and click "Add to Source Control".  The plugin then attempts to add the file to the repository and comes back with an error message "Unhandled exception" stating an access violation with the file named "svncom.dll".
It should be noted that I also have Tortoise SVN installed and using the same repository I can connect and check in and out files.
Attachment 1 is a screenshot of the setup screen inside LabVIEW.
Attachment 2 is another screenshot of the settings in LabVIEW after successful configuration of the SCC plugin
Attachment 3 is what the error message looks like
Anyone have any advice or some step by step instructions on how to set this up?  I have been fighting with this setup for weeks now.
Thanks in advance.
(2,406 Views)
The error message seems like an issue that PushOK would be equipped to address. I would contact them regarding the error in the first picture to see if they have any information on that. It seems that you were able to configure things in LabVIEW properly. The information sent by LabVIEW to the source control providers for operations such as adding a file is pretty basic, so for these kinds of issues it is usually best to contact the source control provider directly.
George M
(2,348 Views)
