LabVIEW webserver on iphone
Is it possible, without using data dashboard, to view and/or control a LabVIEW front panel on an iPhone using LabVIEW Web Server?
(5,119 Views)
I was able to access the text and the border around the front panel on both a windows phone and an iphone, but no indicators or controls showed, just a page icon in the top left corner. It displays ok when clicking on Preview in Browser on the computer it is running on.
(5,103 Views)
No, it won't work. Remote Front Panels require Silverlight and the LabVIEW run-time engine to be installed - neither of which are supported on the iPhone.
You can access LabVIEW Web Services from an iPhone which will allow you to host some web-pages from your LabVIEW application. You could then use other web-services or something like WebSockets with javascript to update the content on the page.
(blog)
(5,071 Views)
Accepted by topic author sfrosty
You probably wouldn't want to just have a VI show up on your iPhone the way it looks on your computer anyway because VIs aren't really designed for a mobile platform. Like, for example the buttons might be too small to press with your finger on such a small screen.
What you need to do is write a web page with HTML, Javascript, CSS (or whatever other tools you might want to use for a web page) and have your LabVIEW web service send data to the web page and have the web page send data back to the web service. Take a look at these tutorials for more info on how to do this: https://decibel.ni.com/content/docs/DOC-41151
For it to work well on your iPhone you just need to design the web page in a way so that is will adjust to smaller screens and still look nice. An easy way to do this is by using Bootstrap: http://getbootstrap.com/
--Hope
(5,065 Views)
