LabVIEW webservice: How to format the published XML data
Im trying to  publish some measurement data with LabVIEW webservice and read the data with Android client. However i have some problems with the XML output from the LabVIEW webservice.
I want to publish the data in in this form:
<Response>
 -<Terminal>
        <Parameter> Temperature</Parameter>
         <Value> 5 </Value>
        <Unit> ºC </Unit>
       <Description> Measurements from Sensor 1</Description>
   </Terminal>
</Response>
Any ideas how i can do this? i havent found any good example on how to format the XML output this way.
(3,986 Views)
Create a cluster with that specification and the XML should look like that. *does quick test*
Hmm, looks like you'll need to create some special function, a simple unbundle and Format into string.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,966 Views)
Does anyone of you got some good example? I am just trying same thing with a compactRIO as web server, where it will receive a cluster for make some settings. My big question is how can I read this cluster to early apply an unbundle function and use my cluster elements?
Thanks in advance!
Alberto.
(3,815 Views)
You can format the data using Format Into String as shown in the attached snippet. Is this maybe something you can use?
Willy
Willy
(3,706 Views)
