LabVIEW with Arduino
Hi guys! I´m working with LabVIEW and making project with Arduino. And I found a error which I can´t solve. I am doing some calculations on a formula node and I am encountering a rounding problem. As you can see in the attached photo, the output of the formula node is 0.14, but I need this output to be 0.143693. Does anybody know how to solve this?output_formula_node.png
(2,586 Views)
Use a probe to verify.  The highlight execution is only displaying 2 digits of precision, where you are looking for more like 6.  But judging from the output of the Format Fractional String, you are getting the value you expect.
(2,576 Views)
The value display on the string wire shows you got the value you were looking for!
(2,552 Views)
