LabVIEW with Tiva C Series TM4C1294
I'm trying to interface Tiva C Series TI Launchpad TM4c1294 board with LabVIEW.
I setup the interface using USB, COM6. I also setup the VISA open, close, read and write.
But, when I run the VI, my read buffer and count displays 0. I'm wondering if there is any communication between LabVIEW and the TI board.
I know the board and the interface is working. I'm able to communicate through C++ IDE. But I'm not sure how to go about doing it from LabVIEW.
I'm able to turn the LED on/off from C++, I'd like to be able to do the same task from LabVIEW. Can anyone give me some directions? Or references?
I came across a similar article:
http://e2e.ti.com/group/launchyourdesign/m/tivaarmmicrocontrollerprojects/665977
But I'm not able to figure out how to do it. Any help would be greatly appreciated.
I have attached my VI.
Here's the link to the code I'm using:
https://github.com/energia/Energia/tree/master/examples/01.Basics/DualBlink_430
Thank you,
(4,549 Views)
Hi GKlab,
Just out of curiosity are you working on a FIRST robotics project?  Just wondering since they use Launchpad.
Anyways, I would suggest that you take a look at all of the examples that come prepackaged with LabVIEW.  You can find them by going to Help>>Find examples in any LabVIEW window.  In particular I would have  you look at the Hardware Input and Output>>Serial>>Simple Serial.VI It gives a pretty good explination and example of how to check connection using the *IDN command.  Good luck!
Pat B
Applications Engineer | National Instruments
ni.com/support
(4,492 Views)
