LabVIEW with the Robotis Dynamixel AX-18A
I am having trouble using the Dynamixel AX-18A with labview. I have found some examples but they all utilize this servo in Joint mode and I am wanting to use it in Wheel mode. Does anyone have any suggestions or examples for me. I cannot seem to alter the VI successfully to accomplish what I'm after. Any thoughts help.
-Isaac
(2,900 Views)
Hello, Isaac
I recommend posting your code if possible. Otherwise, it might be hard for others to help you if they can't see what you're already trying. Also, if you have the links to the tutorials that you have been following then that may be able to provide some more insight into this problem.
Ryan
Ryan P.
CLA
(2,865 Views)
