LabVIEW2012 has long execution time to write string than LabVIEW2011 on XP SP3
@ELI2011 wrote:
I still want to know the reason why LabVIEW 2012 has this difference from LabVIEW 2011, that if write large size string to front panel indicator in for loop, it has long execution time.
Juding by the picture you included, your code is not accurately computing execution time anyway... So what basis do you have to conclude this?
Are you seeing noticable lag/delay on the front panel output?
Going off of the timing calculations you are currently trying to do is just silly.  You don't show us where you initialize the "start time".  You also have the timing calculations in a seperate parallel loop for some reason -- and on top of that, you are mindlessly overwriting the timing calculations over and over during each iteration.  This will eat up a ton of CPU time and will slow down your entire VI execution.
EDIT:
Per altenbach's suggestions, try something like this:  (*Note:  This was poorly drawn in Microsoft Paint, but it should get the idea across, I hope.)
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 11 of 35
(2,290 Views)
My concern is this same source code works fine with LabVIEW 2011 on Chinese XP, but has doubled execution time after upgrade to LabVIEW 2012.
Also, with 2012, it works fine if change the OS language to English from Chinese XP.
So, can we focus on this difference behavior between LabVIEW 2011 & 2012 works on Chinese XP OS?
"I think therefore I am"
Message 12 of 35
(2,272 Views)
There are probably a good amount of changes between LabVIEW 2011 and LabVIEW 2012.  For instance here is a list: http://zone.ni.com/reference/en-XX/help/371361J-01/lvupgrade/labview_features/
But that is irrelevant either way.  You have provided absolutely no proof that the code runs any slower on LabVIEW 2012.  Your current VI, as-is, does NOT calculate execution time.  Please tell me how you determined that it runs slower.
If you actually calculate valid execution times like we demonstrated, then maybe we can suggest reasons why (if at all) it runs slower.
Message 13 of 35
(2,270 Views)
Here is the way how to calculate the execution time: the test program works in a state machine (while loop + case structure), it has following steps include in case structure, that is "Initialize" -> "Testing" -> "Error Handle" -> "Database" -> "Complete".
In Initialize step, it record the start time in a way show in below figure(I do not have source code in this laptop, but give a sample here, hope it can make sense):
Then in Testing step, show in below figure, it will use "current time" substract "start time" as "testing time",  and it will updated in each 10ms.
After all commands execete completed, the trigger "startup" became false, and it will stop the time calculation loop. We will get the final test time then.
Now this LabVIEW 2012 code works fine on English XP & Win 7 OS, the execution time is about 145 seconds, but on Chinese XP OS, the execution time is about 300 seconds.
The same code run with LabVIEW 2011 on Chinese XP OS, the execution time is 145 seconds.
I asked this question to NI application engineer located in Shanghai, they think that maybe a bug, but they can`t tell the root cause, that is why I put the question here.
I highly appreciate your response!
Message 14 of 35
(2,255 Views)
It could very well be a bug, and unfortunately, as I don't have Chinese versions of LabVIEW I cannot attempt to replicate this.
The point I was trying to make, is that your code is NON DETERMINISTIC and the timing calculations are INACCURATE.  Granted the behind-the-scenes of LabVIEW isn't always what it seems, but usually parallel loops execute in different threads.  As a result, many things could happen:
1. The top loop executes first and finishes before the second loop even gets a chance to run (since you flag the "timer" loop to stop when the above loop does.)  This would result in the fastest execution
2. The bottom loop could execute a bunch of times before the top loop even gets a chance to run.  This could add a lot of time.
3. Both loops could intermitantly run.  This could cause lots of context switches that add time.
4. They could theoretically run at the same time depending on the cores of your CPU.
... And so on.
This could be affected by simple things such as background processes, number of cores in your CPU, number of threads different versions of LabVIEW allocate to optimize a program, etc, etc.
Those are all over-simplified, but as you can see there are many ways things could go wrong outside of LabVIEW itself.  (Mostly due to the Windows OS.).  This is why altenbach's recommendation was so good.  Not only does it avoid many threading issues that may arise, he also has a way that will run MUCH faster than the average case with your code.  (Even if they both run simultaneously, your bottom loop will continually "count" as the time progresses in your program.  His computation calculates execution time more accurately and removes any repeat calculations.
Message 15 of 35
(2,248 Views)
I pointed out the benchmarking flaws many days ago, so I assume that this is no longer an issue.
We still don't know the typical loop rate of the code. If it is really fast, I would only set the scroll position a few times per second. It is not economical to hammer property nodes like that.
So the main difference seems to be language version. Are you displaying Chinese characters?
Message 16 of 35
(2,237 Views)
I know that the "test time" is not accurate enough here even though I have added 10ms time delay in both top and bottom loops, but it can be a reference near to the actually execution time. I can't use your calculation way because my test program need to dynamic display the process time, but your way only display a final execution time.
Do you have other solution to record the accurate process time?
Message 17 of 35
(2,235 Views)
Once you add delays, the wait contributes to the loop rate.
How can you admit that the measurement is flawed, but still insist that the speeds are different. If performance really matters, you need to code this differently. A property node in an inner loop is expensive because they are synchronous and require thread switching
Message 18 of 35
(2,232 Views)
I had tried to use the front panel indicator instead of it property a few days before, but just the same issue.
It is not the Chinese characters, but the string size caused doubled execution time! As I mentioned before, the program has about a hundred commands to execute, each of them will output some string, but three of them will output large size string (about 160kB), it caused the later commands execute very slowly! But it will speed up if I remove these three commands.
I create a sample code that cycle write large size string to front panel indicator on Chinese XP and English XP, it can duplicate this issue.
Message 19 of 35
(2,231 Views)
Then please show us your latest sample code. Thanks.
You still haven not give uns anything quatitiative. "slowly" can have many meanings! Can you give actual benchmark times for the two scenarios?
160kb is not large.
Could it be that just the front panel more sluggish? Do you have overlapping elements?
Message 20 of 35
(2,217 Views)
